Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th-200r4 to th350 trans swap questions
Old 06-01-2011, 09:47 PM
SSedan64's Avatar
SSedan64 SSedan64 is offline
Originally Posted by cudablack2004
hey guys have a 90 caprice 305 with a 200-r4 thats on its last leg (the trans)! Recently purchased a th350 27 spline with a 6" tailshaft it was recently rebuilt and the convertor is included as well as tv cable and dip stick. Besides moving the crossmember forward i wanna kno 1. Will the driveshaft work and flexplate? 2.how will i make lockup work? 3. What else do i need to kno to make this swap work?
The TH350/350C uses a Detent cable for Passing gear, it's adjustment not critical like the TH2004R's TV/ThrottleValve cable is.
#1 Driveshaft & Flexplate should work fine.
#2 If you have a TH350C Trans it will have a Lockup TC/TorqueConverter, the standard TH350 doesn't have a Lockup TC.
#3 May need to adjust the Shifter linkage.
