th-200r4 to th350 trans swap questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-31-2011, 07:17 PM
cudablack2004's Avatar
hey guys have a 90 caprice 305 with a 200-r4 thats on its last leg (the trans)! Recently purchased a th350 27 spline with a 6" tailshaft it was recently rebuilt and the convertor is included as well as tv cable and dip stick. Besides moving the crossmember forward i wanna kno 1. Will the driveshaft work and flexplate? 2.how will i make lockup work? 3. What else do i need to kno to make this swap work?
Old 06-01-2011, 09:47 PM
SSedan64's Avatar
The TH350/350C uses a Detent cable for Passing gear, it's adjustment not critical like the TH2004R's TV/ThrottleValve cable is.
#1 Driveshaft & Flexplate should work fine.
#2 If you have a TH350C Trans it will have a Lockup TC/TorqueConverter, the standard TH350 doesn't have a Lockup TC.
#3 May need to adjust the Shifter linkage.
Old 06-02-2011, 06:52 AM
delawarebill's Avatar
trans conv..
on my first bucket... th350 went south and replaced with 200r... a few adjments but fit fine. i didn't use the OD feature.
Old 06-02-2011, 02:37 PM
Its a standard 350 without lockup i have a tv cable with it (thank god) all i need it the bolts to mount the tc to the flexplate unless i can use my 200r4 bolts
#3 May need to adjust the Shifter linkage.[/QUOTE]
200R4 to turbo 350 trans swap hotrod_11_12 Transmission - Rearend 7 03-02-2011 01:31 PM
T-350 & T-400 swap questions fullsize c-10 chlsnk Transmission - Rearend 5 09-02-2009 01:24 PM
swap 700r4 for a th350 in a trans am???? hickey's got a yami Transmission - Rearend 8 08-20-2008 08:05 PM
200r4 swap for a th350 jpd37 Transmission - Rearend 13 04-16-2007 11:02 PM
TH350 swap questions WS6tech Transmission - Rearend 13 11-26-2002 04:03 PM
