th 250 case, same as 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-02-2009, 11:30 AM
Icelander's Avatar
Hi guys, i was looking after empty th 350 case to start my transmission rebuild, cause the case in my Nova is cracked over the bell housing. anyway i found a case that looked at first to be a 350, but when i gave it a better look i saw a four pin electric plug on the side and the input axle appears to be different.
after doing some research on the internet i figure it is a th 250.
At first i got rather disappointed but then i was told i could use it if i am just going to swap the internals. ??
I was actually hoping somebody with experience could verify this for me.
Thanks i advance. Kristofer.
Old 02-02-2009, 01:00 PM
Could be either a TH250C or a TH350C - the four pin connector usually designates the lockup torque converter.
Old 02-02-2009, 05:00 PM
Icelander's Avatar
OK. thanks. But is there any way to spot it out, th 250 or the desired th 350 ?
Best regards. Kristofer.
Old 02-02-2009, 05:11 PM
tnsmith10's Avatar
when will it rain???
a th 250 will have a threaded stud with a nut on it coming out of the top of the case on the right side, just before the bellhousing.
Old 02-02-2009, 05:16 PM
SSedan64's Avatar
tnsmith's right, it's near the cooler line fittings.
Old 02-02-2009, 06:09 PM
Icelander's Avatar
Thanks for responding, it is a th 350
But im not going to use lock up converter, does it matter, i was planning on just swapping the internals from the broken one, she has everything new inside, So this electric plug is just left unused or ,,, ?
Thanks again. Kristofer.
Old 02-02-2009, 07:56 PM
ericnova72's Avatar
More for Less Racer
IIRC, you can't swap parts, the case is different in the valve body channeling, and the valvebody is different also(fluid circuit for the lock up feature) along with the front pump and the case area where the pump sits. I took a TH350C to my race trans builder just to replace the case on my TH 350 and was told it won't work. Maybe someone can give a more definate answer?
Old 02-02-2009, 11:29 PM
Wiki Edits: 85
There is a way to make a lockup case work for a non-lockup, but I don't know what it is. All I know is that I have sold lockup cases to some shops who told me they were modifying them to use in non-lockup applications. This was years ago, so I don't remember who they were either.
Old 02-03-2009, 04:12 AM
tnsmith10's Avatar
yes, it can be done with some mods...
1st you have to change the stator to a non-lockup style stator.
2nd, change the input drum to a non-lockup drum (non lockup wont have the smooth polished tip on the drum)
3rd, you have to block off the valve for t.c.c. apply.
4th, you gotta drill a 1/8th inch hole through the small plate next to the body for t.c.c. control, roughly in the middle of it... its gotta be in the right spot though.
youd be better off finding a non lockup core and going through it, or having someone else do if your not that familiar with automatic transmissions.
Old 02-03-2009, 05:29 AM
Icelander's Avatar
Thanks for the info guys, i think i am better off with another core, i truly am an amateur when comes to transmissions. But if we look at the bright sides then this is the time to study and and do some learning. (cause of the bank crisis)
Hope you all will have a great day. Regards. Kristofer.
Old 02-03-2009, 09:26 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
usually a 1/4 hole is drilled in the non lock up stator suppport .... no hole and the front seal will blow out.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
