TH 350 1-2 Manual shift Feel - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-15-2006, 09:30 PM
TH 350 1-2 Manual shift Feel... shift delay
Im currently wotking on a 350 with about 600hp infront of it , i used a tranzgo shift kit, blocked the 1-2 accumulator with a piece of copper pipe, only one checkball is installed in the case, band is blocked from applying with washers under the servo, im using the large vaccume mod,
now. when im doing a manual shift from 1-2 at about 3/4 throttle aprox 5000 rpm the shift dosent feel positive enough the rpm's can raise 1000 rmp in the time it takes to make the shift. the shift dosent happen immeadeatly, i am using blue plate specials regular steels, im throwin kolines in it tomorow, i set my clutch pack cleaance to about .030 using an extra steel plate, should i have done this or left it with the big gap that it usualy has, none of the frictions are burnt and fluid is clean, mod is adjusted up.. and govenor is functoning correctly, withc i know is unrelated to a manual shift can anyone please give me some advice on this
Thanks
Cam
Old 05-16-2006, 08:24 PM
Anyone????
Old 05-16-2006, 09:07 PM
Crosley's Avatar
Wiki Edits: 1659
Thanks
Cam
which TransGo kit?
Did you change the PR spring?
Which check ball remains in the case? what area is it located near?
Old 05-16-2006, 09:20 PM
its not the stick shift one, 2 and 3 i think with the orange PR spring, checkball closest to the mod left in., removed tranz from vehicke today and found that kickdown cable was non existant, customer did not install it said that it was to hard to put the bolt in it. and i belive this is what caused his failure due to insuficent line rise, took everythin apart int and direct is burnt, air checks are good, all seals are good,
now another question.. red altos or blue plate specials?? bolth with koline steels. witch would benifit this trans more i wanna see opinions the more the better!!!!!
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
4L80E diesel computer 5foot2 Transmission - Rearend 2 04-09-2005 12:48 PM
THM 350 shift improvement early57 Transmission - Rearend 5 04-08-2003 05:47 AM
1965 c10 - 350 w/3.73 rear and manual transmission... nyabinghi Transmission - Rearend 0 01-28-2003 12:37 PM
TH 350 shift problems Bigblazer Transmission - Rearend 5 12-06-2002 02:02 PM
