th-350 to 700r-4 swap? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-04-2008, 08:55 AM
i am about to swap the stock th-350 in my Camaro to a 700r-4 that i have and i know that it will all bolt up the same and everything, but being as the car is a floor shift 3spd auto shifter(stock that came in the car), will the linkage be any different? and also, if i can just "slap er' in" the car, when i go to drive it, will the shift pattern change from PRND21 to PRND321? or is 700r-4 shift pattern the same as a th-350(PRND21)?
thanks,
MuscleCarKid
Old 04-04-2008, 09:48 AM
Sickpuppy22's Avatar
From what i remember your most likely going to have to change the gate in your shifter because you wont be able to get it into you first gear properly, seeing as the gate doesn't have the same amount of notches in it. Also make sure you adjust you linkage as well loosen the linkage screw that is on the bracket set the tranny in park from under the car and set your shifter into park re tighten and check to see if your gears correspond with where your shifter is indicating it.
You will be able to use that shifter but might as well do er right so you can use all your gears
Old 04-04-2008, 10:21 AM
pontiacjosh's Avatar
84 stroked ss
Last journal entry: exhaust
i may be wrong but the driveshaft and the cross member are different also buy if im wrong someone will chime in
Old 04-04-2008, 10:55 AM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
If the 350 is the same length the drive shaft should be fine. You will have to move the crossmember back.
Old 04-04-2008, 10:59 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
a 700r4 /4L60 trans is the same length as a t-350 with a 9 inch tail housing. A Camaro should have a 6 inch tail housing.
TV cable is very important on the 700 trans, must be hooked up and adjusted.
the year of this Camaro ?
Old 04-04-2008, 06:16 PM
the car is a 1979 camaro. would i still have to change the cross member if the 700r-4 came out of another camaro?
Old 04-05-2008, 11:26 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
the 700 trans is longer.
The mount spot is about 2 inches further back than a t-350 trans... so the cross member needs some type of modification.
Old 04-10-2008, 08:37 AM
okay, thank yall for all the help!
350 swap distributor question orvillewho Electrical 5 03-22-2008 02:26 PM
HELP: Olds 350 swap in a 85 Regal Torx Engine 3 04-12-2006 03:55 AM
700R to 350 JH30906 Transmission - Rearend 9 10-05-2005 07:17 PM
350 to 305 swap 78Z Engine 10 02-06-2005 01:42 AM
1978 grand prix chevy 350 swap threesand9s Engine 5 06-28-2004 02:31 PM
