. the tail housing and other parts are not swappable between the 700 & 350 trannys to obtain a tranny that is the correct length for the application.There was at one time an after market kit to adapt a torque arm setup to a t-350 tail housing. A 9 inch tail housing t-350 tranny is the same length as the 700/4L60 tranny. The trans mount is in a slightly different location from a t-350 to the t-700 good luck. post back
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Monza & Starfire used T350 with torque arm bar mount....
will that bolt in place of a t-700 tranny on this Camaro? Will the torque arm reach the t-350 tail housing?
I must discipline myself to read the FULL post...
Tony, you are right, the torque arm bar will NOT reach the T350. Sorry to have misled the lad.... I will retreat in disgrace
OK so I lied.
Try this site: http://www.teckpak-fitzall.com/teckf...witch_kits.htm These parts can be ordered thru a trans shop if you can't get them off their site. Unfortunately, this will require the trans to be torn apart... |
I thought mayb there was something different out there.I learn something new often, problem is I forget 3 things to 1 new. A teck-pak spacer with a 9 inch output shaft on the t-350 would be a good option. Finding the torque arm style tail housing for the t-350 could be difficult. My work place has these tec-pak spacers laying around at times... they come in on the core trannys we buy.
I wonder if the spacer and T350 extension is the same length as the 700 extension by itself...
That way the 700 extension would still fit the car... |
i called all over looking for the conversion bracket to put the 350 in and out of 20-30 shops called one could get it. anyway im ordering it today and should be able to do the conversion on tuesday.
you get the the brackets from B&M for 70 bucks, summit carries them, this is how you install th350 trannies into these cars 82-up camaro and firebird,
my 82 tran am was a thm200c and i put in a th350 out of a 77 G20 van, the bracket works great, it uses the bolts that hold the tailshafthousing to the main case and youonlyneedthe outsidehalf of the torque armmount assembly and the rubber part you either need a 9" tail th350 or a 200c driveshaft from an 82 or 83 camaro or firebird if you have a 6" tail th350. but that driveshaft is not easy to find, it was in 82 and 83 only, the torque arm reaches all the tranny models the torque arm is the same length under all the 82-up f bodies, regardless of the transmission the two driveshafts used under these cars are 3" different in length all 84-up are the shorter one good luck Last edited by fast68; 12-02-2006 at 08:42 PM. |
| Port or Full time vacuum | cool rockin daddy | Engine | 129 | 10-05-2010 03:00 PM |
| Cam/Lifter Question about Ramjet 350 | Jake Harsha | Engine | 20 | 07-07-2010 06:22 AM |
| DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. | Steve-0321 | Hotrodding Basics | 21 | 11-26-2007 12:44 AM |
| 305 head on 350 | savman1 | Engine | 4 | 10-15-2006 09:18 PM |
| 348 or 350 delimma | 62ImpalaSS | Engine | 12 | 05-17-2006 11:03 PM |
