Th 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-04-2002, 06:27 AM
Question Th 350
Hey,
I put a turbo 350 in my car with a 327 engine. My question is, what all needs to be hooked up to the transmission. I feel like i am gonna forget something. Things like trans cooler lines and all tht kinda crap. And what is necessary just to start the engine. Like, is there anything i could jsut not hook up so i can start the engine and hear it?
Thanks for any help
Jordan
Old 01-04-2002, 09:30 AM
Post
Well just to start the motor you are going to definately need the trans cooler lines. There is a vacuum modulator on the trans that will also need to be conected or at least closed off at the intake manifold. If the motor came from a car with power brakes it will also have a place to connect vacuum for the power brakes on the mannifold and will either need to be conected to the brake booster or closed off. This should be enough to get the motor started.
Good Luck
Old 01-04-2002, 10:06 PM
Post
Don't make the mistake and start it with no fluid. It makes no differance weather you are going to drive it or not you need fluid. So the main things are drive shaft and cooler lines. Don't be in to big of a hurry it could cost you time and money. ROY
Old 01-05-2002, 06:49 PM
Tom Tom is offline
Post
don't forget the belhousing bolts and the converter bolts
