th 350 circle track use
hey guys got a few questions for the tranny pro's
a friend of mine is building a bomber for the local circle track and has asked me to rebuild a 350 turbo for the car. ive done a few trannys for my own street strip cars, but nothing for circle track, he only has intentions of running the trans in first gear at all times, what kinda mods should i look into for his trans to insure the durabilitly of being in first only, rules say he can run a glide. thanks Greg |
First gear...all the time ? what size is the track ? 1/4 mile,1/2 mile ?
when I ran street stock we went with a TH400 that was used in a Grumman the Th400 used in heavy trucks and motor homes have a lower gear for 1st and 2d. With a few mods it served us well, but we could run 2d gear on a ½ mile track with the right rear ratio. Now the old glide can be tricked out, a friend of mine had one in his sportsman dirt racer. No convertor , with a valve to in gauge it in drive. If your track rules allow this I would find someone to trick it out. No convertor = less weight, less overheated trans fluid , but was a bit tricky to get use to at first. http://www.powerglide.com/parts/parts/GM-DD-1K.htm |
actually the rules state no powerglides, the track is a 1/4 mild banked paved oval, other people have ran the 350's in first with a 2.73 gear with success in the past,but no im going to be building a trans for a friend. and was wondering what i can do to make the trans survie fulltime 1st gear use.
thanks, Greg |
| Distributor Tuning and Theory - Part 1 | Rick WI | Engine | 35 | 04-26-2011 12:38 AM |
| Cam/Lifter Question about Ramjet 350 | Jake Harsha | Engine | 20 | 07-07-2010 06:22 AM |
| Bog/Black Smoke on Olds 350 at 3000 rpm | JohnTN | Engine | 4 | 03-17-2009 11:39 AM |
| Circle Track cams?? | GearHead69 | Engine | 11 | 04-15-2006 09:15 PM |
| circle track 350 | firebomb71 | Engine | 4 | 08-24-2003 08:00 PM |
