Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH 350 cooler line oil flow
Old 09-27-2012, 07:29 AM
jeepers creepers jeepers creepers is offline
Originally Posted by SSedan64 View Post
The Bottom line is the Feed/Out which has pressure.
The Top line is Return/In, it doesn't have suction so some fluid may flow out there.
Radiator with side tanks:
Bottom = Feed/In from bottom Trans line.
Top = Return/Out to top Trans line.
Thank you, that's what i've thought so i put my finger on the return/in line to see if it has any pressure but i can easily stop the flow, in the other line has a little bit more pressure , i hope that's enaugh to create a flow in the circuit cooler otherwise it's a problem.
