Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH 350 cooler line oil flow
Old 09-27-2012, 06:17 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
Design of the trans pump , stator and input shaft... With wear on the bushings and shaft, the oil takes the path with least resistance, so oil flows out each port with nothing attached.
With a cooler and lines installed , the oil is pushed the correct path.
