Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH 350 cooler line oil flow
Old 09-28-2012, 12:41 AM
jeepers creepers jeepers creepers is offline
Originally Posted by Crosley View Post
Design of the trans pump , stator and input shaft... With wear on the bushings and shaft, the oil takes the path with least resistance, so oil flows out each port with nothing attached.
With a cooler and lines installed , the oil is pushed the correct path.
You made me an happy man for today, thank you!
By the way , tranny has been freshly rebuilt and i changed as weel all the bushings.
