The Bottom line is the Feed/Out which has pressure.
The Top line is Return/In, it doesn't have suction so some fluid may flow out there. Radiator with side tanks: Bottom = Feed/In from bottom Trans line. Top = Return/Out to top Trans line. |
| The Following User Says Thank You to SSedan64 For This Useful Post: | ||
jeepers creepers (09-27-2012) | ||
Thank you, that's what i've thought so i put my finger on the return/in line to see if it has any pressure but i can easily stop the flow, in the other line has a little bit more pressure , i hope that's enaugh to create a flow in the circuit cooler otherwise it's a problem.
You can check the pressure before and after the cooler(s) to see if there's excessive pressure drop. |
Design of the trans pump , stator and input shaft... With wear on the bushings and shaft, the oil takes the path with least resistance, so oil flows out each port with nothing attached.
With a cooler and lines installed , the oil is pushed the correct path.
At the Bonneville Salt Flats, first gear is known as 130 mph. |
By the way , tranny has been freshly rebuilt and i changed as weel all the bushings. |
| Engine oil cooler on GM SB 350 | jeepers creepers | Engine | 3 | 09-07-2012 12:15 PM |
| Chevy 350 oil cooler bolt | SamCam | Engine | 6 | 03-30-2012 09:07 AM |
| Being told my radiator / oil cooler setup wont flow properly ... | lowROLLERchevy | Hotrodding Basics | 11 | 10-08-2011 11:33 PM |
| Air cooled powerglide change to cooler line flow? | nanaimoBC | Transmission - Rearend | 9 | 10-18-2010 06:48 AM |
| turbo 350 with cooler flow problems? | pontiacjosh | Transmission - Rearend | 0 | 08-08-2009 08:57 AM |
