Th-350 cooler lines..where do they go - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-16-2003, 03:58 PM
V8 S-10's Avatar
v8s10.org
I'm pretty sure that the top cooler line goes to the top of the radiator and the bottom goes to the bottom of the radiator. Anybody know for sure?
Old 09-16-2003, 06:54 PM
Richie Z's Avatar
New Member
Angry
I would like to know the same thing on a th400. upper fitting on trans, is it a feed or a return?
Old 09-16-2003, 08:39 PM
Upper is the return line.......
Lower is the output line......
Old 09-17-2003, 08:39 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Re: Th-350 cooler lines..where do they go
does not matter what line goes where on the radiator. there are NO check valves in the system to stop flow one direction over the other
