TH-350 Cooling Lines Flaring - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2006, 08:40 PM
72NOVA454
Help
I am about to do flaring on 5/16 steel lines for my TH-350 trans to my new external trans cooler. Do I use a single or double flaring tool for this job? I know brake lines are double - what about trans lines? What is a typical pressure (psi) in a TH-350 trans cooling line under normal operating conditions?
Old 01-02-2006, 08:46 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Single is fine.
I use steel brake lines joined with brass.
Less than 20 psi. Remember lots of people used fuel line for trans hose for years and never blew any lines up.
Old 01-02-2006, 08:53 PM
302 Z28's Avatar
I also use preformed, preflared brake lines from the auto parts stores for fuel and trans cooler lines, it's real cheap.
Vince
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
possible 350 block purchase - comments please idrva55 Engine 17 12-09-2007 09:29 PM
350 ... Need I Say SB or C??? horvath Engine 25 07-17-2003 03:20 PM
