TH-350 Detent cable bolt size - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2011, 02:15 PM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
Do any of you guys happen to know what size bolt is used to secure the detent cable to the trans case? I tried a 1/4-20 and an M6, no go.
Thanks for any help. I'm trying to do this on my back under the truck and for some reason I don't see as well as I used to. LOL
Old 07-13-2011, 01:26 PM
tnsmith10's Avatar
when will it rain???
it depends on the year of the case... early cases will take 1/4-20, the late cases will take the m6.are you sure the threads are ok going into the case? also, on the th350, the detent bolt does not go in straight up and down, it has a angle to it..
Old 07-13-2011, 03:34 PM
S10Fan's Avatar
Garage Filler
I was finally able to get closer and clean out the threads. 1/4-20 did the trick, I didn't want to force it, like I would have in the past. LOL
Thanks!
Help with detent cable V305 Transmission - Rearend 1 04-09-2009 09:33 PM
detent cable? sexypizzaman Transmission - Rearend 18 12-18-2008 08:11 AM
Detent Cable? HammerGVette Suspension - Brakes - Steering 0 04-16-2007 11:08 PM
replace a t-350 detent cable? fishkiller Transmission - Rearend 2 03-08-2007 08:54 PM
tv cable bracket bolt size help 39chevy Transmission - Rearend 1 04-14-2004 08:01 PM
