Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Th 350 Detent problem
Old 03-01-2004, 02:38 PM
Thom Laybourne's Avatar
Thom Laybourne Thom Laybourne is offline
TV Cable
Sounds like you are talking about the TV cable from the trans to the throttle plate. It also sounds like you are now running a 350 engine with a 350 transmission now. If all this is correct, then you need to get a TV cable adjustment procedure. Full open throttle and fully pulled cable should match. Release and the carb will return further than the TV cable. I am not sure, but there is nothing inside the transmission that you can bend by over pulling the cable. Might have bent the bracket at the carb.
hr41pearl
