TH 350 Front Pumps. Difference ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2012, 03:04 AM
Hi,
I just disassembled a TH350 for spare parts. When I disassembled the front pump I notised that there is a small valve in the housing. Will this pump assembly interchange with the "normal" pump assy.? The trans may have been a TH350 lock up. There is a switch mounted in the right hand side, next to the cooler lines, but the input shaft is not a lock up type. Will all hard parts be useable for parts in non lock up versions?
Thanks, Tom.
Old 02-22-2012, 04:24 AM
Wiki Edits: 85
All non-lockup pumps interchange. Same with lockup pumps. Major difference between LU and NonLU is length of stator support shaft.
Old 02-22-2012, 05:45 AM
pricesgarages's Avatar
theres some diffrences in non lock up pumps a vega pump is air cooled if u use it it it will vent fluid out of the breather the ball and spring was used in 69 then it was changed
Old 02-22-2012, 10:21 AM
Wiki Edits: 85
Vegas were not built in 69, so did not have the ball and spring.
Old 02-22-2012, 10:35 AM
Thank You for your answers. The valve I mentioned is x-tra. The ball is there too. This x-tra valve sits in the open when you takas the 2 halves of the pump apart. The valve is about 11 mm diameter with a spring below. you can remove it with your fingers. Thanks, Tom.
Old 02-23-2012, 12:31 AM
no the 69 had the ball and spring the vega wich was introduced in 1971 was air cooled and had a diffrent pump wich cannont be used in a a regular 350
Old 02-23-2012, 10:52 AM
Wiki Edits: 85
I have been selling 350 pumps for 30 years and the ONLY question I have ever asked is, "lockup or nonlockup" to determine which type of application. Vega 350 pumps have the same OEM part numbers as any other 350 pump of the same era and work just fine in any other nonlockup application.
The only significant differences amongst nonlockup pumps is the ball and spring for 1969 and the steel sleeve with extra ring for 80 and up. They ALL interchange, though the 80 and up are preferable because they tend to last longer. Because of the longevity of the 80 and up, it is the ONLY one I sell nowadays into ALL nonlockup applications, INCLUDING Vega.
Old 02-23-2012, 01:24 PM
rick 427's Avatar
Last journal entry: The 32's
MMERLINN..Your post indicates that you are selling 80 up pumps for non lock-up 350's...80 up pumps were lock-up pumps.....didn't you mean ''pump bodys''....and not the complete pump??
Old 02-24-2012, 12:25 AM
Wiki Edits: 85
Minor typo on my part. 80 was last year for nonlockups and first year for lockups. I should not have said "up" just "80" instead of "80 up."
LU pump bodies are different than NonLU pump bodies. The LUs have thicker gears. I have no idea whether one should interchange them or not.
Old 02-24-2012, 12:55 AM
rick 427's Avatar
Yea,I know the pump bodies are different...I thought for a minute that you were maybe selling an aftermarket piece....good used pumps are getting hard to come by in these parts.
Old 02-24-2012, 10:08 AM
Wiki Edits: 85
I have never seen an aftermarket pump for a 350, though I have seen aftermarket shift kits and conversion kits for some applications. I don't think there is enough demand for anyone to make aftermarket 350 pumps, especially since good used are still generally available relatively cheaply.
Old 02-25-2012, 12:27 AM
Where do you buy those good used pumps?
Old 02-25-2012, 07:18 PM
Wiki Edits: 85
Wrecking yards.
Gear in this thread - Powered by O'Reilly Auto Parts
REO pumps Jeff The Ruler Engine 3 10-03-2009 02:40 PM
T-400 front pumps are they interchangeable Overdriv Transmission - Rearend 9 08-07-2009 11:55 AM
oil pumps 101 k-star Engine 26 05-22-2006 10:00 PM
Gas Pumps Kevin45 Hotrodders' Lounge 4 10-05-2002 03:56 PM
oil pumps truckin chuk Engine 4 03-22-2002 04:22 PM
Copyright ©2000 - 2016, vBulletin Solutions, Inc.
