TH 350 leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2007, 11:06 AM
ajd ajd is offline
TH 350 leak
Have a leak in a TH-350 tranny i think might be the kick down cable? Is it necessary to run the kick down cable or can i block it off?? I had the same leaking spot and the same amt in my last tranny-so I thought buying a new one would fix it ----WRONG---there has to be some answer for this. Should i silacone the area of the kickdown cable before installing the cable itlself?? I need some help with this one.
Old 06-18-2007, 06:33 PM
Crosley's Avatar
Wiki Edits: 1659
IF you are using a cable with the rubber sealing sleeve...... the sleeve must be installed into the case first. then the cable end is lubed up and pushed into the sealing sleeve. then bolt down cable
IF you install the rubber sleeve onto the cable first, then attempt to push the cable into the case .... it will leak every time.
Old 06-19-2007, 07:50 AM
ajd ajd is offline
th-350 leak
Thanks for the info I will give that a try, makes sense to me!!!
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
rear seal leak on sbc 350 4onthefloor 2 Engine 9 03-23-2005 03:04 PM
