TH 350 leak - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2011, 06:43 PM
TH 350 leak
I cannot get my dipstick tube to quit leaking. I have tried the o ring type and grommet type stick and lots of silicone on both. It still leaks. What do you suggest??? Anyone???
Old 04-12-2011, 06:45 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
It's not a chrome one is it ? And is it bolted to the block or not ?
Cole
Old 04-13-2011, 08:01 PM
el pollo's Avatar
It's shady under this tree...
Dipstick tubes are pressed in with an o-ring at the bottom. Never had one leak on me. Is the transmission overfilled?
Old 04-13-2011, 08:15 PM
eloc431962's Avatar
Wiki Edits: 37
I have had them leak before, they press in and then most have a bracket that bolt to through the bell housing to the block. JMO
Cole
Frustrating Powerglide Leak or Torque Converter Leak? 67Elcamino Transmission - Rearend 2 08-26-2009 11:16 AM
Oil Leak de64 Engine 1 08-24-2007 03:37 PM
oil leak donb1964 Engine 7 08-17-2007 08:13 AM
Ford power steering box leak (steady leak) StevenC Suspension - Brakes - Steering 7 06-17-2005 09:36 AM
No Leak Thom Laybourne Engine 3 03-24-2004 05:54 PM
