Th 350 Leaking from tailshaft vent??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-14-2008, 11:55 PM
Vegaguy's Avatar
Hi everyone, here's my problem. I have a th350 behind a sb 350 in a vega. The trans has the short tailshaft. It always pukes out the tailshaft vent for some reason. I had it on stands running in gear and sure enough it coming out. I removed the tail housing and everything looks ok. It keeps leaking out until its to low to run and starts slipping. I rebuilt this tranny myself. It was my first th350 but not my first rebuild. Did I miss something? I dont have a clue why its leaking out of the vent. Any help would be greatly appreciated. Thanks in advance for any help.
Mark
Old 06-15-2008, 02:08 AM
C-10's Avatar
Revolution Calling
Last journal entry: Poverty caps live on.
Tail shaft vent?
Are you referring to that round piece if tin pressed in the backside of the yoke with a hole in the center?
The only vent that is supposed to be in this trans is on the very top of the case about halfway back.
I've welded the caps in the yokes before, as well as the pin hole in the center. Usually the yoke has a missing spline to vent any fluid back into the extension housing.
Some output shafts have a pressed on 'can' with an o-ring to seal the yoke that way.
If you totally degrease the cap and the the surrounding areas on the yoke, I bet one could use JB weld to seal it. Never tried it, but it may work.
Old 06-15-2008, 03:21 AM
Vegaguy's Avatar
Its a plastic pressed in tube on the top of the tailshaft housing. Its not the yoke. I'll try and see if I can get a good pic of it and post it tomorrow since its up on stands right now, but thanks for the reply.
Old 06-15-2008, 06:52 PM
Vegaguy's Avatar
Here is the vent i'm talking about. Can I plug this vent without blowing out seal or something. There is still the vent on top of the case. I'm tired of loosing all my tranny fluid all the time.
ID:	30613   Click image for larger version
Old 06-15-2008, 07:48 PM
C-10's Avatar
Revolution Calling
There SHOULD be a passage from the main case into the ext. housing, thus allowing the tail to be vented into the main case. If you pop off the tail housing and there is, I would go ahead and plug the tail vent.
That's a weird leak, are you sure you are not over full?
Old 06-15-2008, 07:51 PM
Vegaguy's Avatar
Not over full, if I drive it enough it will leak untill the fluid is to low to drive. Going around the slightest curves the fluid goes to the side away from the pickup and feels like nuetral. Inside the housing the vent tube is curved and about 1 1/2" long.
Old 06-16-2008, 12:14 AM
C-10's Avatar
Revolution Calling
But this is the one you wish to plug?
I mean if the tail is not sealed from the rest of the case, go ahead and plug the tail vent. The extension housing and the case will now basically share the same case vent.
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 10:43 AM
leaking turbo 350 fast 79 malibu Transmission - Rearend 2 06-09-2008 10:33 AM
Turbo 350 Leaking & Kickdown Problems... onefine56 Transmission - Rearend 2 01-06-2008 09:28 PM
turbo 350 kickdown leaking!!! What to do? solgood71blazer Transmission - Rearend 1 02-06-2003 04:13 AM
leaking cowl vent ping001 Body - Exterior 2 04-10-2002 12:52 PM
