Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Th 350 Leaking from tailshaft vent???
Old 06-15-2008, 06:48 PM
C-10's Avatar
C-10 C-10 is offline
Revolution Calling
Last journal entry: Poverty caps live on.
There SHOULD be a passage from the main case into the ext. housing, thus allowing the tail to be vented into the main case. If you pop off the tail housing and there is, I would go ahead and plug the tail vent.
That's a weird leak, are you sure you are not over full?
