TH 350 leaks and can't find where... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2006, 04:34 PM
Augusto's Avatar
From the middle of the world
Last wiki edit: How to rebuild an engine Last photo:
how can I find where the oil is coming from? the pan gasket is not, the link shaft seal is not either, the pump's definitelly not, could there be a crack in the case? is this possible? I also suspect of the vent, how could the oil come out the vent if possible? I don't think is overheating.
thanks
Augusto.
Old 08-28-2006, 04:47 PM
66ImpSS396's Avatar
It's been fun
Th350
some of the old th350 Alu cases had a problem with case porosity fluid bleeds through the case because of the casting process (there was a fix in the 78 service manuals to clean the case and coat with two part epoxy) Not a transmission expert just something I read while in the service manual) Hope that helps.
BarryH
Old 08-28-2006, 05:11 PM
coupster's Avatar
I just went thru a similar problem with mine. I was just about ready to pull the tranny and do a reseal when I noticed an unused pressure switch next to the dipstick tube. I removed it and used a pipe plug in its place, leak fixed. Mike
Old 08-28-2006, 06:59 PM
Augusto's Avatar
do you put the epoxy in the outside of the case?
I don't have the switch.
Augusto.
Old 08-28-2006, 07:56 PM
66ImpSS396's Avatar
It's been fun
Case Porosity repair
here is the section from the service man.
Hope this helps! I've never done this myself just remembered reading the problem fix mya. I didn't like getting under it while running and test bit Be really careful with that.
BarryH
Old 08-28-2006, 09:26 PM
New Member
350 leak.
Check to see if there is a small hole in the center of output shaft U joint. I mean small (.030) Some have a vent and some have a small hole! Took me a while to find my leak. Good luck.
Old 08-29-2006, 11:40 AM
Augusto's Avatar
thanks for the instructions,
I've heard of the hole before but could not remember until now, thanks for the tip.
Augusto
