th 350 lock up - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2007, 09:01 AM
racer rick's Avatar
th 350 lock up
i have a th350 c trans and want to put a 2400 stall converter into it .what i need to know is can i install a non lockup coverter into my trans without any mods to my trans . i have herd that i have to change my pump assembly to a non lockup style .truck has been changed from standard to auto trans lockup was never hooked up and has worked fine. high stall lockups cost 4times what non lockup cost
Old 04-01-2007, 09:38 AM
airworld2's Avatar
no you can not install a non lock up converter, you can change pump and forward drum but you need to drill relief whole for lock up oil or front seal will blow out. what converter are you looking at that cost 4 times as much as non lock up? the cost should be slightly higher on lock up.
airworld2
Old 04-02-2007, 07:35 PM
fast68's Avatar
likes chevy trucks & boobies
i need elaborated info on this relief hole, i have a th350c from an 81 pickup and it had a diesel 350 oldsmobile in front of it i junked the TC and have been trying to find a gas engine version of TC for it all to no avail, for a couple years now, perfectly good tranny would love to use it
if i could swap the input shaft and drum and whatever to a non lockup that would be great
so i could finally use this tranny
details ?
thanks
Old 04-02-2007, 07:45 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
details ?
thanks
you must swap in a non lock up pump & stator support.
then non lock up input shaft, also plug the hole for lock up solenoid.
Block the lock up valve in place in the small secondary v-body'
drill hole in stator support as this photo shows.
Old 04-04-2007, 07:41 PM
racer rick's Avatar
priced out a tci conv for 188non lock 475 for lock version
Old 04-16-2007, 11:05 PM
fast68's Avatar
good to learn
why cant you instead of drilling the hole just use a non-C stator suport that should already have the hole in it ?
no ?
and 475 for a converter ?
wow...
forget all that
ill just look for a good used stock or rebuilt th350c converter for my 81 one
dang i finally found one online!
about freakign time, ive been looking for almost two yearsfor a th350c converter
sheesh..
http://www.bulkpart.com/Merchant2/me...roduct_Count=0
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
Bog/Black Smoke on Olds 350 at 3000 rpm JohnTN Engine 4 03-17-2009 11:39 AM
Why not a 350 sbc? bowtieorbust Engine 29 09-05-2008 09:43 AM
Where is the best place to find a 350 engine Andrew7dg Engine 8 10-20-2005 04:28 PM
350 price? hcker2000 Engine 4 08-02-2004 12:48 PM
