Th 350 Long Shaft What Did It Come In - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2007, 05:34 PM
What Years Did The Long Shaft Did The Long Shaft Come In And What Did It Come In Any Answer
Old 12-26-2007, 05:38 PM
runn141's Avatar
SB S10
73-87 1/2 ton chevy trucks 2wd.
Old 12-26-2007, 05:41 PM
Crosley's Avatar
Wiki Edits: 1659
What length shaft?
besides the common 6 inch shaft , there is a 9 inch and a 12 inch out put shaft.
12 inch was used in station wagons , usually Buick - Olds
Old 12-26-2007, 06:04 PM
runn141's Avatar
SB S10
i was referring to the 9 inch shaft.
Old 12-27-2007, 02:59 AM
Re Shaft
I Need A 9in Shaft
Old 12-29-2007, 12:27 AM
DR132's Avatar
Sophisticated Minimalist
I'm pretty sure the 9" tail shaft models were used in 2wd vans from around the same years as the 2wd trucks runn141 was talking about
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 10:00 PM
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
sb 350 camshaft installation New Or Old Gears? Brawler Engine 12 07-15-2007 01:08 PM
Shaft rocker trouble uhhh not good Venturat Engine 1 08-04-2003 09:24 PM
350 engine rebuild question (long) 84bird Engine 4 07-23-2003 05:48 PM
