TH 350 lost 3rd gear and reverse is weak - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2009, 06:28 PM
junior stocker's Avatar
A couple of weeks back I posted about the TH 350 in my 82 3/4 ton truck shifting HARD into 3rd gear. Well, yesterday, I lost 3rd gear altogether, and reverse is slipping bad. Parked the truck rather than do further damage. I guess the direct clutches have gone away. This is a TH 350 with the 9 inch extention housing. Will a short shaft TH 400 go in without anything other than a slip yoke change? Truck has a 2 piece driveline. I could rebuild the TH 350, but would a TH 400 really last longer? I guess I would have to get a different trans mount, and move the cross member back a few inches also, not a problem. The trans fluid looks/smells OK. Now, I already have a complete TH 350 rebuild kit, but I was planning to use that in a short shaft TH 350 I also have for another project. Engine's a stroker 305/334 and runs fine. It's just a big truck, and this is the second TH 350 to go bad in it now. Originally, the truck came with a 700R4, but it was the first year for that trans and it only lasted 16,000 miles. G.M. paid 85% to backdate it to a TH 350, as there were'nt many folks up on the 700R4 at the time. I've lost faith in these TH 350, medium duty transmissions. What would you do? Thanks.
Old 05-29-2009, 04:20 PM
Have a TH 400 now.
Well, I just picked up a remanned TH 400, so I'm committed to swapping out the TH 350. I guess I'll have to have the front half of the 2 piece driveshaft "lenthened" 3" or so. Or, can I just toss the 2 piece driveline and have a one piece unit made? Advice? Thanks.
No reverse gear and slippage in Drive 2nd gear. jadejoky28 Transmission - Rearend 14 04-09-2009 11:49 AM
4L60E Weak Reverse rsruss800 Transmission - Rearend 3 03-23-2008 05:00 PM
Reverse idler gear chumbucket Transmission - Rearend 0 12-28-2005 05:20 AM
General reverse and 1st gear ?s in auto trans scot Transmission - Rearend 3 12-17-2005 10:09 AM
T-56 NO MORE 4TH GEAR, and NO 3RD GEAR SYNCOS!!! chevyelc81 Transmission - Rearend 5 12-05-2004 10:39 AM
