th 350 not comming apart question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2009, 05:59 PM
Pulled all the superficial stuff off, now taken the bolts out of the end that holds the main guts in. B&M book says just give er a chuck,,eeeeyyyyaaaa right. I been shakin this thing like a dog with a rag toy. Just how stuck they suppose to be? Seems to me its a spigot fit or am I missing something
Old 11-16-2009, 07:35 PM
BOBCRMAN@aol.com's Avatar
After you get the bolts out of the pump to case. Look into the bolt holes and you will see that the pump has threads in two holes. 3/8 course. Take a couple of 3/8 bolts about 2" long and use them in a couple of different ways.
Get a piece of chain with links large enuff to get a 3/8 bolt thru. Install bolts thru chain into the pump housing. Leave enuff chain hanging that you can get a pry bar (or 2x4 lumber) between the chain and the bell housing. Pry the pump forward. Or use a 5 lb. hammer and wrap the chain around the end and use the hammer as a slide hammer. A couple of hard pulls and the pump will come out.
You will see a large O-ring. Also a paper gasket. Crap gets into the case and locks up the case to pump clearance. That is what makes removal difficult.
Old 11-17-2009, 02:58 AM
Wiki Edits: 85
Or do what I do.
Remove the valve body and then use a screw driver to pry the pump out.
Old 11-17-2009, 06:41 AM
thats what I've been doing.I'll just do it harder
Question about RamJet 350 iceman36 Engine 1 03-07-2006 11:13 AM
350 rebuilt to 383 question jtswilson Engine 17 03-02-2006 11:54 AM
5.565 rods & 350 piston question Mustangsaly Engine 30 10-01-2005 07:16 PM
Distributor Question - 1985 305 and 1975 350 Fragzem Electrical 3 10-28-2003 11:07 PM
350 motor question bubb rubb Engine 4 03-25-2003 05:45 PM
