th 350 oil level - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2005, 06:52 PM
4doorjoe's Avatar
th 350 oil level
got a stupid question when checking fluid level on th 350 should be hot trans in park on level ground should engine be shut off to check . i checked it while it was running it shows 1 pint down i check it cold it shows just over the full mark so should engine be shut off to check. thanks joe
Joe sammut
Old 07-28-2005, 10:31 PM
My dipstick says to check it while engine is fully warmed up, and idling in gear.
Sometimes I use park but if I have a friend present I put it in drive with e-brake on.
Old 07-30-2005, 07:54 PM
adtkart@aol.com
Most all auto trans have on the dip stick how to check the fluid. They tell to check with engine running, and warm, and either in Park or Neutral. Checking one with the engine off will usually cause a high reading due to the fluid that has drained back from the convertor. When you first start it, the fluid will be picked up, causing a lower reading. They you wait and the fluid level will raise as the temperature raises. I really don't recall any that said to check it in gear. I must have missed that one.
Low oil pressure at idle on rebuilt 350 Palmtrees57 Engine 25 02-13-2004 11:30 AM
GMC 350 Top End Oil Problem bns2002 Engine 16 12-11-2003 04:29 PM
Tip of the day on oil additives that you need to read mcgyver-ky Engine 10 04-19-2003 06:17 AM
Should I change my oil? 48Man Engine 2 01-29-2003 08:28 AM
oil in a 350 zerr63 Engine 2 10-31-2002 04:39 PM
