th 350 problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2011, 07:24 PM
th 350 problem
my th 350 wont shift by itself. i got it from a guy who said he use to race the trans. i have taken it apart. put a valve body off another th350 thas was shifting fine when i took it out( thinking it could have been a full manual vale body). the module is new. i can shift manually but when i put it in drive it will be in third but wont shft through the gears. idk whats going on with it
Old 10-17-2011, 05:34 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is the modulator still hooked up and what source for vacuum is it hooked to ? just reaching here.
Cole
Old 10-17-2011, 08:11 PM
yeah its still hooked up and the vacuum is from the carb. the trans i had before was a th350 and it shifted fine never had a problem with it shifting (till it got wore out). but this is a whole different trans. and actually the valve body is from the other trans that i didnt have no problem from. the guy had washers in the kickdown lever valve? so it wouldnt shift down. but i took the washers out and hooked the kickdown cable back up right. but wouldnt think that would stop it from shifting through all the gears
Old 10-19-2011, 07:32 PM
i would take a look at the govenor some man/vb use clips on the govenor weights to hold them open
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 12 05-29-2015 08:57 PM
problem, problem, some ideas please awert Engine 2 06-21-2009 08:20 PM
timming problem?? or carb problem???? helppp 85 k5 mud truck Engine 9 06-05-2009 02:29 PM
having a wiper problem in my chevy truck, and a taillight fashing problem in my GMC ChevyJim Electrical 5 01-28-2006 08:20 AM
starter problem ? timing problem? 6speedwagon Engine 1 08-11-2004 12:37 PM
