Ok guys I was out in my chevelle having a good time playing around and trying to put the power to the ground. I blew up my rear end ok not a problem that I was not expecting. So pull it into Canadian tire parking lot get a tow home. Nothing hurting but some pride and my diff.
As pulling the chevelle into the garage at home I tell a friend of mine to pull it out of park before proceeding to pull it in with my come along. Up to this point everything worked fine. He tells me that he cant get it to go past reverse. Ok so he just doesn't know how to work my shifter, he should it's only a B and M quicksilver pretty basic. What every I blamed it on stupidity ( we all have brain farts once in a while). So tonight I go out and was sitting behind the wheel and was going to play a little while I'm waiting on parts( go through the gears once or twice) I can't shift past reverse. "what the he11" so take it all apart make sure shifter is working right. YUP. Make sure the cable is free and I didn't bend anything external. EVERYTHING IS GOOD. So I have come to the conclusion that it is internal within the trans. Any ideas because I'm transmission impaired. Last time I had one apart was to change the pump gear and that was not the best experience. That bent clutch and pump gear still hangs on the wall as a reminder not to do that again.
If you have a idea what could be causing me not to shift past reverse. would I be able to do the fix my self or is that a no?? I should be able to do it if it is basic, but beyond that I need a good reference material.
sorry kinda got long winded telling the story
Thanks,
John
