Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th 350 problems
Thread: th 350 problems
Old 05-14-2006, 10:14 PM
projectjohn projectjohn is offline
I did tow it home in neutral, but the trans was not spinning because the spiders were blew out of it. I checked that before I left. So that should not be the cause of the problem. And the tow was not anymore than 15 blocks.
The tow was with a rope. And a Caprice.
In that case the shifter would shift past reverse, but the trans wouldn't work. This seems like the shifting linkage internally is binding and not letting me shift past that one spot.
Thanks for the quick reply
