Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th 350 problems
Thread: th 350 problems
Old 05-15-2006, 07:51 AM
cucumber1949's Avatar
cucumber1949 cucumber1949 is offline
T-Bucket, Corvette, Mustang
Disconnect the transmission end of the B&M shifter cable from the lever on the transmission. Can you move the shifter lever by hand thru the gears and detents? If so, the shifter is bad, If not, drop the pan on the trans and make sure the linkage from the trans lever is connected internally.
