Originally Posted by vmann77
drag racin 6 months ago i lost 2nd gear.i replaced the intermidate servo piston it was cracked now their is a aluminum piston in it. i also put a tci manual valve body that has no 1st gear engine breaking. i was at gainsville this weekin racin trans worked great except on the last pass .at the 1000 ft. mark third gear felt like it broke .it bounced off the limiter like it was in nuetral when i got to the shutdown i fired it back up and i works fine PLEASE HELP ME THANKS!
Posssible high gear (direct) clutch problems.. The clutch may hold under lighter power , not hold full power.
Is the fluid level OK?
No engine braking in manual 1 gear or manual 2nd gear?
