Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - th 350 problems
Thread: th 350 problems
Old 12-12-2007, 07:49 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
Originally Posted by vmann77
The valve body is designed for no engine braking just in 1st manual 2nd will brake. The part number is tci-321000 .I just test drove the car about 2 miles.It shifted fine till 3rd manual then down shifted into 2nd back to 3rd like it was in passing mode. But their is no linkage going too the detent control valve .I have removed the detent cable years ago. I was at full thottle when it happens but doesnt do it all the time.The fluid looks great and is full THANKS.
sounds like a problem in the direct clutch.... the trans is not down shifting , 3rd gear is coming off.
When a t-350 shifts to 3rd gear , 2nd gear remains applied, the roller clutch over-runs. When 3rd gear comes off , the roller clutch engages and you are in 2nd gear again
What is the history on the trans? Fresh rebuild with this v-body? Old trans with v-body change?
