Assemble gears with "dots" on gear faces towards you. There is no "timing" reference for the gears. The dots refer to gear placement in the pocket.
Be sure to aling th epump passages before tightening the halves. Check the bolt holes to be sure they are all aligned. Using the case bore to center the pump halves is a good idea if you do not have a pump band. |
| Front pump question | Jmark | Transmission - Rearend | 1 | 05-12-2004 09:46 PM |
