TH-350 Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2012, 07:26 PM
tc33's Avatar
Stuck in the 30's
Last journal entry: Where it came from and how I got there - a short Summary
TH-350 Questions
TH350 K case three speed automatic transmission - THE H.A.M.B.
Take a look at the picture on the link above. Specifically, picture 1 of 6. What is the port on the driver's side near the top of the case? I started filling my trans and after quart 8 I got overflow out of it???? The motor was not running while I was filling an empty transmission. The fitting is loose and seems to be plastic. Is it some sort of presure bypass???
Old 07-12-2012, 07:37 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
That is the vent for the case. You should not have fluid come out of there unless it is way over full.
Old 07-12-2012, 08:25 PM
ericnova72's Avatar
More for Less Racer
The engine needs to be running when you fill the trans, otherwise it will come out of the vent, just like you had happen. The torque converter will not fill unless the front pump is turning to pump it full.
Old 07-12-2012, 08:29 PM
tc33's Avatar
Stuck in the 30's
Thanx guys, I appreciate the info and direction.
Old 07-12-2012, 08:39 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Although not important to the question here:
That ad on the HAMB is not a K case t-350 4x4 trans as the seller indicates.
An actual K case t-350 trans is a 4x4 case with bolt on cast aluminum dust cover.
Old 07-13-2012, 02:08 AM
Wiki Edits: 85
Also, the non-lockup K case is 78-79 only and VERY VERY hard to find a good one.
350 build questions, looking for 300-350 hp Jaiden2010 Engine 18 06-23-2011 08:49 AM
turbo 350 and Olds t-350 questions Black S10 Trk Transmission - Rearend 2 05-26-2009 02:17 PM
turbo 350 and Olds t-350 questions flatheadfever Transmission - Rearend 3 02-12-2006 09:41 PM
49 chevy: putting in a 350/350 questions blastered Transmission - Rearend 11 09-15-2005 08:42 PM
T-350 questions cjg Transmission - Rearend 2 11-14-2004 06:48 PM
