thanks. illl check my timing, and re-adjust ( if needed) the carb also, thanks chop top and duece. but... whats the "sun shell rubbing the case, bell mouthed and abused when bushings go out". ? im a starter to this. i coulda sworn id adjusted the idle/mixture screws on the carb (original two barrel) previously. and i could have sworn ,but i have to look into it somemore, that i threaded them out 2 & 1/2 turns, but like i said i coulda sworn. also. another thing thats off subject. my uncle just gave me some used headers, and two of the pipes are smashed in, semi. not eccesive, but still. will this be a problem? or should i try and pull the dents out a little? cutting and welding is no problem, but looking to see what you guys think about a semi-imperfect exhaust. thanks
