Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Transmission - Rearend
  #1
Old 03-15-2003, 04:52 PM
b/w72 b/w72 is offline
Post th-350 rebuild question
the book i bought says that after i install the input ring gear it should give more resistence when rotating in a ccw direction the in cw direction. Mine has the same amount of resistence in both directions. Can anyone help me out with this or should i not worry about it? thanks for any help ben
Old 03-15-2003, 05:16 PM
toymobile toymobile is offline
Post re: th-350 rebuild question
dont worry with it, if you put trany in park i think you will fine what they are talking about, good luck. JF
Old 03-16-2003, 09:30 AM
Crosley's Avatar
Crosley Crosley is offline
Moderator guy
 Crosley's barnstar
Cool re: th-350 rebuild question
B/W,
what happens is the roller clutch holds in one direction as you spin the output shaft, the other direction the roller clutch over-runs.
As the roller clutch holds you will be spinning a drum in the oppisite direction. this is where the additional resistance comes from.
If the frictions are dry(no oil yet) the resistance will feel nearly the same in both directions.
Be kind to your children... some day they may be decide what nursing home to put you in
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
