Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - TH 350 Reverse Manual Valve-body Questions
Old 11-24-2011, 09:00 PM
Crosley's Avatar
Crosley Crosley is offline
Wiki Edits: 1659
The converter will need to be cut open and cleaned , also checked for any damage inside, check hub, ect.
Reverse pattern valve bodys are usaully built for max effort shifts, so yes the accumilators are often deleted.
There are a couple of folks here that will post up some links for your parts chasing .
It may be a broken 2nd gear sprag race and related parts to that sprag. that is just a guess at this point till the unit is torn down
The Following User Says Thank You to Crosley For This Useful Post:
qsharp84 (01-07-2013)
