TH-350 reverse problem. - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2006, 01:45 PM
The transmission shifts fine from 1-2-d or if i manualy do it works fine too. But there is no revirse at all. At first there was it was slipping in revise for about 1 min or 2 then theres none now nothing at all.
Any answers or sugestions would be greatly apriceated.
Old 03-28-2006, 02:31 PM
Skylark_77_455's Avatar
Do you have an aftermarket shifter with that is cable operated, mine fell out of adjustment, a little tightening and it did fine. check that out.
Old 03-28-2006, 05:08 PM
M&M CUSTOM's Avatar
Wiki Edits: 9
If you "rev" the engine does it go into reverse faster?, NOT that you should go out and try it if you haven't.
I had the same problem with a TH-350 and it also sucked fluid through the modulator, along with leaking from every possible place it could.
Mine was in desperate need of a rebuild.
Old 03-28-2006, 05:21 PM
I also went for a drive and its pooring its guts out with trans fluid. lmao what the heck is up with this tranny lol any one know i would be very apreciated.
Last edited by M&M CUSTOM; 03-28-2006 at 08:02 PM. Reason: Profanity filter bypassing, is not allowed.
Old 03-28-2006, 06:59 PM
Wiki Edits: 31
I'd say it might need a rebuild.
Old 03-28-2006, 07:08 PM
Yea, I'd say that tranny is toast! lol... I had the same problem... If you're interested, I have a TH350 that I rebuilt three months ago. Has a stage 3 shift kit. I can't use it on my car. I'll sell it to ya for $100.
Last edited by M&M CUSTOM; 03-28-2006 at 08:03 PM. Reason: Profanity filter bypassing, is not allowed.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 01:38 AM
94 Saturn trans-axle reverse drive problem xk8 Transmission - Rearend 1 01-19-2006 07:35 AM
GMC 350 Top End Oil Problem bns2002 Engine 16 12-11-2003 04:29 PM
350 turbo in vette problem mikeweyman Engine 2 03-26-2003 08:00 PM
Fuel / Carb problem DoubleVision Engine 5 10-28-2002 06:18 PM
