TH-350 shift kit/TH-400 rebuild - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-14-2010, 10:37 PM
Caprice Sleeper's Avatar
Can anyone recommend a good shift kit for a 82 TH-350 non lock up tranny. It will be put behind a 383 that is going in my caprice. Also i have a 77 CJ-7 with a TH-400 that needs a rebuild, my question is will any TH-400 rebuild kit work in this 4x4 tranny. I have done some research on this tranny and i think that GM made this model TH-400 with a jeep bolt pattern bell housing, some CJ's came with a GM bell housing and used an adapter plate to attach it to the engine and some had the jeep bell housing. I dont know if that will make a difference when buying a rebuild kit. Just so there is no confusion im not trying to put the 4x4 TH-400 into my caprice i just wanted to see if anyone could give my some info on it while i asked about the TH-350 shift kit.
Old 04-15-2010, 07:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
TransGo products will work well for your project
Turbo 400 rebuild kits thatshimman Transmission - Rearend 1 11-28-2009 10:59 AM
my turbo 400 won't shift!! skylark65 Transmission - Rearend 2 07-01-2007 07:58 PM
What to Choose 350, 377, 383, or 400 Nobodyknows Engine 8 03-16-2006 05:50 AM
400 th shift kit help gpeak Transmission - Rearend 2 01-07-2004 04:51 PM
diff between 350 and 400 jo5hi3 Engine 1 09-30-2003 09:43 AM
