th 350 shifting issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-15-2005, 03:42 PM
frankenstang57's Avatar
waynenewtoneVil
Last journal entry: plans
I just bought an '80 Vette with an auto. I believe it's a TH350, but I am still cutting my teeth on GM products so I may be wrong. The trans engages all the gears, but won't upshift to drive unless I manually shift it. If it drops to 2nd when I get on it, it will stay there until I drop the shifter down then back up. Ant sugestions? The car has been sitting for a few years, would changing the fluid help out? Thanx!
Old 04-15-2005, 08:22 PM
astroracer's Avatar
Definately change the fluid and put in a shift kit while you've got it opened up. The upshift thing sounds like you might have a bad vacuum modulator. Take the car to a tranny shop and have them check it out.
Mark
Old 04-20-2005, 03:56 PM
waynenewtoneVil
Well I finally crawled under the car today to have a look. The hose for the vm was rotted in half. I replaced it and it works like a charm. Thanx!
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
350 Chevy Issues engine trouble... Please help me! ineedspeed Engine 26 07-28-2008 04:23 AM
turbo 350 issues D. Robbins Introduce Yourself 2 11-14-2004 09:16 AM
Chevy 350 Timing issues Dans83Olds Engine 3 09-04-2003 02:22 AM
camaro transmission still not shifting chevcamz28newbie Transmission - Rearend 2 07-20-2003 07:33 AM
