Thm 350 stays in first gear
Just in case it does not have a manual valve body-do you have vacuum to the modulator? Does it have a modulator?
Was it sitting someplace where water could have been introduced into the trans? What does the fluid level and condition look like? |
Agreed... does it free wheel when you let off the gas or does it provide braking? If it free-wheels, its not getting a vacuum signal.
To answer your questions,
-It is a manual valve body b/c there is no modulator. -There is a plug w/silicone where the modulator would be. -It has NOT been sitting anywhere were water could of got into it. -The fluid level and condition are good. -It does NOT free-wheel when I let off the gas. I still think that a valve has stuck so I might put some additive in it to see if that will work them loose. |
TH-350 stays in first gear
Because of the way most manual valve bodies are made,passages cut to redirect fluid,and valves pinned in place,I'm not guessing a valve is stuck.
Check to make sure the manual valve is indexed correctly[manual linkage]. I have seen shifters not adjusted right which will in turn keep the manual valve inside trans from positioning correctly. Please post back. |
My dad brought home a vacuum modulator from work where he had another th350 sitting around. We are going to put it in and see if it solves the problem. It might be a long time before we get to see b/c the weather has been pretty bad lately.
| Need Help with 700r4 No 4th Gear | Jackson63 | Transmission - Rearend | 6 | 10-09-2006 09:35 PM |
| White Smoke, I'm at a loss | 58Chev | Engine | 31 | 09-25-2006 04:29 PM |
| Low idle vaccum in gear on SBC 350 | hotrodf1 | Engine | 14 | 04-12-2006 07:21 AM |
| lost 3rd gear on th 350 | Hot_Rod_Faith | Transmission - Rearend | 13 | 12-28-2003 12:39 PM |
| 4x4 700R4 to 350 swap | Davesblazer87 | Transmission - Rearend | 4 | 12-22-2003 07:59 PM |
