TH 350 swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-18-2007, 08:13 PM
TH 350 swap
Hi all,
I have a '78 TH350 that is gone and I now have a '83 TH350 from a Pontiac, they are identical side by side but the only difference is, on the '78 tranny the neutral start, back-up lite switch is mounted by 2 bolts on the side of the tranny with 4 wires leading to a plug, the '83 tranny has a square blue plug-in with 4 holes, only one wire is used and it goes to a coil and then to a sensor. Is this the neutral start/back-up lites switch? Can I use this tranny with my 305 in my '76 Chevy Van? Is there a way to mod this to work. What would happen if I left it unplugged?
Thanks for your help
Old 06-18-2007, 09:48 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by habfan72
Hi all,
the trannys are very different... the 83 unit is a t-350C or a t-250C trans.. these are lock up converter type trannys. The wires are for lock up on the converter , not neutral switch
A t-250C is ID'd by looking near the cooler line fittings on the passenger side of tranny.. Is there a threaded stud with nut protruding from the case near this area? If there is , it is a t-250C tranny
the 78 tranny will be a non lock up trans .
Physical size wise they are very close IF the tail housing is the same length... they will interchange with each other when the matching torque converter is used.
The lock up converter does not need to be hooked up if you so desire... trans will not over heat if done so with converter not locked up.
Old 06-19-2007, 03:10 PM
Th250C swap
Thanks Crosley for your quick reply, it is a th250C tranny, has the stud where you said it was. Both have a 6" tailstock so it will fit to my 305 block. I'll have to make up a bracket to hold my old neutral start/back-up lites and swap over a few parts from the old tranny.
I have a heavy duty th350-th400 torque converter, new for this tranny, a bit bigger and beefier than the original one, 1600 stall speed they say, have to change my flexplate (153t) to a 168t one to fit the converter.
Bottom line I guess is will this set-up work with my th250C tranny and no damage will be done by not using the lock-up connection.
The tranny is going in a Custom '76 Chevy Van, never see's winter, used as an R/V, and will be towing a 20ft tent trailer or 18ft boat, maybe see's 2500 miles a year and well taken care of
Thanks again
Jim
Old 06-19-2007, 08:32 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
A t-250C tranny is for a low horse power situation / vehicle...
Old 06-20-2007, 04:15 PM
Th 250C tranny
Thanks Crosley, understood, make due with what I have for now, p/u this tranny, rebuilt, for pocket change.
I'll get a th350 or 400 later for a project, be happy if this one lasts the summer.
Jim
Old 06-28-2007, 05:54 PM
Th 250C tranny udate
Swap successfull, runs fine, no vibrations, etc. somehow got it right!
Thanks for the info/help Crosley.
Here's what I put it in,
'76 Chevy 10 1/2 ton van, 1,362,422 orig miles, 5 engines and 6 trannys
Jim
Buick 350 auto to manual swap, need info SkylarkCustom71 Transmission - Rearend 7 04-27-2006 08:29 PM
HELP: Olds 350 swap in a 85 Regal Torx Engine 3 04-12-2006 04:55 AM
350 to 305 swap 78Z Engine 10 02-06-2005 02:42 AM
1978 grand prix chevy 350 swap threesand9s Engine 5 06-28-2004 03:31 PM
400 to a 350 engine swap any tips?? sparks55918 Hotrodding Basics 8 11-15-2003 05:27 PM
