th-350 and th-350c - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-20-2008, 08:10 PM
85-monte's Avatar
Last journal entry: 1985 Monte carlo LS
th-350 and th-350c
i was wondering if anyone had any pictures of the bottom of the tranny determining if it is a 350 or 350 c let me know it would be very much appreciated
Old 10-20-2008, 10:07 PM
Crosley's Avatar
Wiki Edits: 1659
both of these trans use the same pan shape.
You need to look for electrical plug on the drivers side near the shift linkage... that will indicate a t-350C or a t-250C trans.
To ID a t-250C trans... look near the cooler line fittings on the passenger side.. slightly to the rear of the fitting may be a threaded stud with nut protruding from the case... this indicates a t-250C
Old 10-27-2008, 07:01 PM
The 350C has a ribbed oil pan. 350 is smooth.
Old 10-27-2008, 07:42 PM
Crosley's Avatar
Wiki Edits: 1659
and what is the pan has been replaced?
Most of the ribbed pans on a 350C leaked with age and were replaced with regular steel pan of the t-350.
