th 350 or th 400 for drag racing
hey! i was wondering what would be better for drag racing, a th 350 or th 400
its gonna be behind a 454 with around 500 hp and 580 ft lbs of tourque |
It depends on your budget. A 350 turbo can be made to live, but is spendy!!
A 400 turbo can be made to live with little more than a good build, a shift kit and some heavy duty sprags.. Broken bellhousings are seldom the fault of the trans.. |
use the t-400 with 34 element sprag for 2nd gear
IF you use the t-350 trans , you should use a 36 element sprag for 2nd gear.. That would be best for the power level you have and be dependable. That t-350 drum is very custom built.. about 440.00 dollars the power loss / use difference between the t-350 and t-400 is too much talk about nothing for what you are doing
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Invest the money now and go with a powerglide, if you plan on racing for a awhile you will be going this direction sometime, might as well invest the money once on a lighter, less horsepower robbing unit. The th400 is the cheapest to build, but if you use a th400 and you want to switch to a glide later, then the driveshaft will have to redone. Dimmensionally the glide and th350 are the same.
Go with the Glide, they are easier on parts, more consistent. |
Midnight Sun Street Rod Association |
Big difference between a top sportsman and an average bracket unit. You can do a lot with a glide and $1150.00. That will get you a unit reliable to go into the 9's and handle 950 horse.
350/400
it really depends on the weight of the car,i run a glide but im putting out 650 hp.and my car is 2k lbs.if your over 2800lbs with 500 hp a turbo would be a better choice for you.as far as a 350 v/s a 400 with a big block go with the 400 as crosley said do the sprag .
| I have a 350 crate engine i want to make atleast 400 hp. | chevydragster83 | Engine | 36 | 08-26-2012 12:47 PM |
| Centrifugal advance | DENCOUCH | Engine | 7 | 05-07-2010 06:39 PM |
| TH 350 & TH 400 Converters | south65ss | Hotrodding Basics | 6 | 11-26-2005 02:21 PM |
| 350 or 400 sbc | young_gun | Engine | 10 | 04-25-2005 08:42 PM |
| 350 with 400 rods? | slider in wa | Engine | 6 | 11-06-2002 04:27 AM |
