TH 350 trans front seal ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-30-2009, 07:55 PM
This will be my first time changing my front seal! I am in the process of pulling trans out. Will the seal be between the torque converter and trans? Advise because this is my first time! Can I stand it up to do this or what? Thanks again, Dana
Old 08-30-2009, 09:13 PM
Crosley's Avatar
Wiki Edits: 1659
pop the seal , drive the new one in.. very simple.
If you have a leak there , it could be more problems with a worn bushing or the bushing move out of the pump body
Need some help on 350 chevy 1 piece seal block eric32 Engine 13 05-03-2009 12:39 AM
HELP front crank seal for a 66 430 Conti adeptus_mechanicus Engine 1 06-02-2007 05:14 AM
TH-350 front pump seal nova72000 Transmission - Rearend 9 09-23-2006 03:17 PM
79 Trans Am engine swap to 350 JTedd Engine 1 05-10-2004 03:52 PM
350 4x4 trans to 700R4 2x4 trans swap??? punk1c5040 Transmission - Rearend 1 02-01-2004 11:14 AM
