-   -   TH 350 Transmission (http://www.hotrodders.com/forum/th-350-transmission-115228.html)
bct 05-02-2007 08:36 PM
TH 350 Transmission
My Chevy TH 350 transmission makes what sounds to me like a scraping sound in all gears. The fluid is nice and red and doesn't smell burned. The trans shifts fine. While I'm going down the road I slip the trans into neutral and the sound goes away. The scraping sounds like metal sliding against metal and is pretty loud. Thanks for any ideas.
Crosley 05-02-2007 08:46 PM
cracked flywheel..
flywheel rubs on the dust cover if there is one.
:cool:
bct 05-02-2007 09:08 PM
Would the sound stop when I shift into neutral if its the flywheel? I haven't put the dust cover on yet.
topdogger 05-02-2007 11:07 PM
I'm having a very similar issue with my transmission. I just put mine in and it sat for a few years. I'm thinking with mine I have some rust buildup in the tranny.
What's the history on your tranny?
malibu68 05-02-2007 11:41 PM
i have the same problem, i have a th400 and when i fire it up it sounds like something is goin to die. there is a lound scraping metal on metal sound. i think it is the flexplate. i saw there is a part that on the flexplate that was hittin the side of the tranny.
bct 05-04-2007 08:07 AM
I drove the doner car into my garage, pulled the trans and put it into my 55. It worked fine before I pulled it. The only thing I did different was add a floor shifter. Now that I think about it I didn't have the original speedometer cable. I wonder if that could have something to do with it? Plus, I'm still not sure if the sound would go away when I put it in neutral if it was the flex plate.
Crosley 05-04-2007 06:47 PM
Cracked flex plate under NO load will often be quiet , unless it is really broken in pieces.
No load would be in park or neutral.
