TH 350 Transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2007, 08:36 PM
bct bct is offline
TH 350 Transmission
My Chevy TH 350 transmission makes what sounds to me like a scraping sound in all gears. The fluid is nice and red and doesn't smell burned. The trans shifts fine. While I'm going down the road I slip the trans into neutral and the sound goes away. The scraping sounds like metal sliding against metal and is pretty loud. Thanks for any ideas.
Old 05-02-2007, 08:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
cracked flywheel..
flywheel rubs on the dust cover if there is one.
Old 05-02-2007, 09:08 PM
bct bct is offline
Would the sound stop when I shift into neutral if its the flywheel? I haven't put the dust cover on yet.
Old 05-02-2007, 11:07 PM
topdogger's Avatar
Newskool
Last journal entry: New, Used grill arrived!
I'm having a very similar issue with my transmission. I just put mine in and it sat for a few years. I'm thinking with mine I have some rust buildup in the tranny.
What's the history on your tranny?
Old 05-02-2007, 11:41 PM
malibu68's Avatar
i have the same problem, i have a th400 and when i fire it up it sounds like something is goin to die. there is a lound scraping metal on metal sound. i think it is the flexplate. i saw there is a part that on the flexplate that was hittin the side of the tranny.
Old 05-04-2007, 08:07 AM
bct bct is offline
I drove the doner car into my garage, pulled the trans and put it into my 55. It worked fine before I pulled it. The only thing I did different was add a floor shifter. Now that I think about it I didn't have the original speedometer cable. I wonder if that could have something to do with it? Plus, I'm still not sure if the sound would go away when I put it in neutral if it was the flex plate.
Old 05-04-2007, 06:47 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cracked flex plate under NO load will often be quiet , unless it is really broken in pieces.
No load would be in park or neutral.
buick 350 - chevy 350 72buick Engine 23 10-13-2009 08:38 PM
Chevy 350 to a Buick transmission steveskylark Transmission - Rearend 6 07-16-2005 11:44 PM
transmission problem turbo 350 jester429 Transmission - Rearend 1 10-04-2003 07:34 PM
Turbo 350 Transmission Leaking 63 vette Transmission - Rearend 2 02-19-2003 05:02 PM
1965 c10 - 350 w/3.73 rear and manual transmission... nyabinghi Transmission - Rearend 0 01-28-2003 12:37 PM
