Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Th-350 troubles
Thread: Th-350 troubles
Old 12-20-2009, 07:41 PM
Bonhorst Bonhorst is offline
Th-350 troubles
I have TH-350 bolted to a 353 sbc (carb, no computer), latley the tranny has been "disengaging" i guess, when i stop, the enging is still running but i have to rev up to about 4000 to get it re-engage and go the fluid is at the full mark, and doesnt smell burnt at all. today i pulled out on to the road and gave it full throttle, it smoke the tires pretty good untill the engine started to bog down and sputter, then the tranny made a god awful noise that sounded like someone had just spun the wheel of fortune, so i pulled over, shifted to park did some inspecting, nothing was missing, the fluid was good, and the engine ran just fine, however when i tried to leave the scene, every gear acted like nuetral. i have no inspection cover on the flywheel so i can see the TC is still there and spinning (probably should fix that) any ideas as to where i should go from here? any info helps, thank you
