th 350 troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2005, 07:32 PM
gab's Avatar
gab gab is offline
th 350 troubles
i installed an edelbrock 1405 w/ electric choke on a 2101 performer manifold in my sons 84 chevy truck (305)
runs great however the trans doesnt shift unless done manually on a soft take off. at wot it will shift.
it was fine before. vacuum is hooked up to manifold and kickdown cable is attached. i have tried to set the kickdown cable and it has made no difference in this soft take off. we also took off all emissions and ac that wasnt used. there is an electtrical connection on trans near the speedo cable this is not hooked up? should it be? and to where?
any help would be apprecited thx
Mike
Old 01-13-2005, 08:07 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
I have an 86' about like your truck, I too had that same problem when I put a similar setup like yours on my old 305 before the old engine died. On mine there was a vacuum line that went from the front of the carb and ran all the way to the back of the transmission on the passenger side. I'm not exactlly sure what it does but there are 2 vacuum holes on the front of the carb it will work on, the one on the left is for emissions and the one on the right for no emissions. If this isn't the problem then someone else on this board should be able to help more than I can.
Old 01-13-2005, 08:12 PM
gab's Avatar
gab gab is offline
i have the vacuum line attached to manifold at its fitting like it was originally and i do have vacuum at that source
thx for reply
Old 01-13-2005, 09:31 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Cool
have you verified good vacuum at the modulator?
Old 01-13-2005, 09:35 PM
gab's Avatar
gab gab is offline
i did verify it at manifold and made sure line was clear
can i pull line off at valve to check then?
Old 01-13-2005, 09:50 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
I recieved an email about this same question. I believe the email came from you at this board
I will ask you for the third time,
did you verify there was good vacuum at the modulator? IS the hose on the modulator? Is the hose bad / cracked at the modulator?
If you pull the vacuum hose off the modulator and oil comes out where the hose attaches, the modulator is bad.
these items need to be checked
Old 01-13-2005, 10:05 PM
gab's Avatar
gab gab is offline
Yes there is vacuum at the modulator i just checked it hose is good also no leaks and modulator is dry no oil or fluids coming from it
Old 01-15-2005, 10:32 PM
tnsmith10's Avatar
when will it rain???
check the govenor... since it seems that u have vacuum down at the modulator and it dont shift... sounds like it has a broken gear on it., or its loaded with trash and stuck... if thats ok, then it may have internal issues. that electrical connector that u found is for the torque converter lockup switch. in an 84 chevy truck, if it didnt have a overdrive then the lockup 350 that u have is possibly the origional unit... if so, then there should be a connector that plugs in to that connector u found somewhere around the bellhousing area.
Old 01-17-2005, 10:14 AM
gab's Avatar
gab gab is offline
problem solved
for some reason even though vacuum was present at the modulator from the manifold the trans still didnt shift
a switch to vacuum port on carb took care of it but not sure why
vacuum seemed same
any way thx to all you guys for your help
Gab
